I have created a new MM instance (self-hosted) for testing which has issue with plugins.
The plugins are ‘enabled’ via the System Console and config.json file.
When I start MM, I am getting the following error:
info [2024-04-30 13:22:01.780 +01:00] Starting up plugins caller=“app/plugin.go:191”
error [2024-04-30 13:22:01.780 +01:00] Failed to start up plugins caller=“app/plugin.go:199” error=“mkdir ./client/plugins: no such file or directory”
The directory is here and has the same permission and ownership as the rest of the application directory.
When I go to the the System Console/Plugins section the following error appears as well:
info [2024-04-30 13:23:29.602 +01:00] Plugins have been disabled. Please check your logs for details. caller=“web/context.go:113” path=/api/v4/plugins request_id=6yrqd8bddfyktjfe7857a948uc ip_addr=X.X.X.X user_id=iyriqi4cwin9xyon5ic1d1y36c method=GET err_where=GetPlugins http_code=501 error=“GetPlugins: Plugins have been disabled. Please check your logs for details.”
Any thoughts or suggestions where to look?
Many thanks
