Problem with Database Config not being Read
A while back I had problems installing on Windows and setting up MySQL. It seems the config file does not get read and it uses some default mysql@localhost, but that username is not in the config file anywhere.
Error 1045: Access denied for mysql@localhost
I’ve seen 3 other theads with the same issue but no resolution. It just seems to work after a bit.
https://forum.mattermost.com/t/error-failed-to-ping-db-retrying-in-10-seconds-err-error-1045-access-denied-for-user-mmuser-localhost-using-password-yes/3676
Wrong String in Settings
