Request for Documentation: Deploy Mattermost on Docker (regarding "sudo chown -R 2000:2000")
In the docker-compose installation doc, under “3. Deploy the Mattermost Docker setup by running:”, we have:
sudo chown -R 2000:2000 ./volumes/app/mattermost/
Is this assuming the user:group of the user is 2000:2000, or does it have to be 2000:2000?
For example, should people check with this first:
$ id my_username, which is usually 1000:1000, then replace the guide with:
sudo chown -R 1000:1000 ./volumes/app/mattermost/
Thanks!
Would you be open to sharing this on our documentation repo: https://github.com/mattermost/docs/issues?
Hi @amy.blais,
Yes, it’s here:
Thanks.
