I am running docker-compose and was able to run Mattermost on my system. But my version does not work in Safari. So i filed an issue and the def. answer is:
Hi @Yzord, this issue should be fixed on master, you should be able to see the fix if you use mattermost/platform:dev.
But when i edit my docker-compose.yml file with
mattermost:
image: mattermost/platform:dev
ports:
- 80:80
restart: always
I get the following error
Recreating 2d47ed9b3fbe_mattermost_mattermost_1
Pulling mattermost (mattermost/platform-dev:latest)…
Pulling repository docker.io/mattermost/platform-dev
ERROR: Error: image mattermost/platform-dev not found
How can i run the latest dev version with docker-compose?
