Running from a subfolder / context
Is it possible to run Mattermost from a sub-folder / context?
I want to run Mattermost behind a Apache2 reverse proxy server and I cannot create sub-domains. So for example I want to access Mattermost as https://example.com/mattermost. I cannot use a sub-domain for example https://mattermost.example.com
Is this supported? Are there configuration examples for Apache2 that shows this?
Hi again, @sugarmoose
While it is not officially supported, may I know if you have tried the documentation here - Configuring Apache2 as a proxy for Mattermost Server (Unofficial) ?
If yes, would you mind sharing the issue that you ran into after configuring the proxy?
