I setup focalboard using docker however when I try and sign in it wipes my login details as if it’s reloading the page constantly.
I installed docker and ran the command:
docker run -it -p 80:8000 mattermost/focalboard
This worked fine for the 2 minutes I played with it but then I ran it via this command:
docker run -d -p 80:8000 mattermost/focalboard
Since I wanted to make it headless. After that is when I began to have the issues and now I’m running it the way I initially ran it to see what was going on.
The page continues to “refresh” in a sense, it wipes all the text I place into the login page boxes trying to sign in. I’m unsure if it’s an database issue or not.
Something about the database not working properly and the websocket?
debug [2022-09-13 17:36:23.634 Z] attachSession caller="api/auth.go:459" single_user=false
debug [2022-09-13 17:36:23.635 Z] API DEBUG caller="api/api.go:4881" code=401 error="unable to get the session for the token: sql: no rows in result set" msg= api=/api/v2/users/me
debug [2022-09-13 17:36:23.647 Z] Command: AUTH caller="ws/server.go:149" client="192.168.1.81:63947"
debug [2022-09-13 17:36:23.647 Z] authenticateListener caller="ws/server.go:436" token=kezhxa1hjopy79jx71unks7iraa wsSession.userID=
error [2022-09-13 17:36:23.647 Z] ERROR WebSocket caller="ws/server.go:130" client="192.168.1.81:63947" error="read tcp 172.17.0.2:8000->192.168.1.81:63947: use of closed network connection"
debug [2022-09-13 17:36:23.647 Z] DISCONNECT WebSocket caller="ws/server.go:119" client="192.168.1.81:63947"
debug [2022-09-13 17:36:35.485 Z] attachSession caller="api/auth.go:459" single_user=false
debug [2022-09-13 17:36:35.486 Z] API DEBUG caller="api/api.go:4881" code=401 error="unable to get the session for the token: sql: no rows in result set" msg= api=/api/v2/users/me
debug [2022-09-13 17:36:35.500 Z] Command: AUTH caller="ws/server.go:149" client="192.168.1.81:50012"
debug [2022-09-13 17:36:35.500 Z] authenticateListener caller="ws/server.go:436" token=kezhxa1hjopy79jx71unks7iraa wsSession.userID=
error [2022-09-13 17:36:35.500 Z] ERROR WebSocket caller="ws/server.go:130" client="192.168.1.81:50012" error="read tcp 172.17.0.2:8000->192.168.1.81:50012: use of closed network connection"
debug [2022-09-13 17:36:35.500 Z] DISCONNECT WebSocket caller="ws/server.go:119" client="192.168.1.81:50012"
debug [2022-09-13 17:36:38.524 Z] Command: AUTH caller="ws/server.go:149" client="192.168.1.81:50013"
debug [2022-09-13 17:36:38.524 Z] authenticateListener caller="ws/server.go:436" token=kezhxa1hjopy79jx71unks7iraa wsSession.userID=
error [2022-09-13 17:36:38.524 Z] ERROR WebSocket caller="ws/server.go:130" client="192.168.1.81:50013" error="read tcp 172.17.0.2:8000->192.168.1.81:50013: use of closed network connection"
debug [2022-09-13 17:36:38.525 Z] DISCONNECT WebSocket caller="ws/server.go:119" client="192.168.1.81:50013"
debug [2022-09-13 17:36:41.554 Z] Command: AUTH caller="ws/server.go:149" client="192.168.1.81:50014"
debug [2022-09-13 17:36:41.554 Z] authenticateListener caller="ws/server.go:436" token=kezhxa1hjopy79jx71unks7iraa wsSession.userID=
error [2022-09-13 17:36:41.554 Z] ERROR WebSocket caller="ws/server.go:130" client="192.168.1.81:50014" error="read tcp 172.17.0.2:8000->192.168.1.81:50014: use of closed network connection"
debug [2022-09-13 17:36:41.554 Z] DISCONNECT WebSocket caller="ws/server.go:119" client="192.168.1.81:50014"
debug [2022-09-13 17:37:08.722 Z] attachSession caller="api/auth.go:459" single_user=false
debug [2022-09-13 17:37:08.723 Z] API DEBUG caller="api/api.go:4881" code=401 error="unable to get the session for the token: sql: no rows in result set" msg= api=/api/v2/users/me
debug [2022-09-13 17:37:08.732 Z] Command: AUTH caller="ws/server.go:149" client="192.168.1.81:50017"
debug [2022-09-13 17:37:08.732 Z] authenticateListener caller="ws/server.go:436" token=kezhxa1hjopy79jx71unks7iraa wsSession.userID=
error [2022-09-13 17:37:08.733 Z] ERROR WebSocket caller="ws/server.go:130" client="192.168.1.81:50017" error="read tcp 172.17.0.2:8000->192.168.1.81:50017: use of closed network connection"
debug [2022-09-13 17:37:08.733 Z] DISCONNECT WebSocket caller="ws/server.go:119" client="192.168.1.81:50017"
debug [2022-09-13 17:37:11.758 Z] Command: AUTH caller="ws/server.go:149" client="192.168.1.81:50019"
debug [2022-09-13 17:37:11.758 Z] authenticateListener caller="ws/server.go:436" token=kezhxa1hjopy79jx71unks7iraa wsSession.userID=
error [2022-09-13 17:37:11.758 Z] ERROR WebSocket caller="ws/server.go:130" client="192.168.1.81:50019" error="read tcp 172.17.0.2:8000->192.168.1.81:50019: use of closed network connection"
debug [2022-09-13 17:37:11.758 Z] DISCONNECT WebSocket caller="ws/server.go:119" client="192.168.1.81:50019"
debug [2022-09-13 17:37:14.785 Z] Command: AUTH caller="ws/server.go:149" client="192.168.1.81:50020"
debug [2022-09-13 17:37:14.785 Z] authenticateListener caller="ws/server.go:436" token=kezhxa1hjopy79jx71unks7iraa wsSession.userID=
error [2022-09-13 17:37:14.786 Z] ERROR WebSocket caller="ws/server.go:130" client="192.168.1.81:50020" error="read tcp 172.17.0.2:8000->192.168.1.81:50020: use of closed network connection"
debug [2022-09-13 17:37:14.786 Z] DISCONNECT WebSocket caller="ws/server.go:119" client="192.168.1.81:50020"
