Can’t send emails because there is no value for “sender”
Not entirely certain, I have entered in my SMTP server and credentials, and it connects but I get this error.
Connection unsuccessful: Connection unsuccessful: failed to set the from address: 530 5.7.1 You (myemail@somewhere.com) are not authorized to send mail as the null sender (<>)
Other things to note… I did not end up going through the standard install path as I couldn’t make the non-SSL install work properly. It would fail on the nginx restart on focal/ubuntu 20.04. Looking at systemd, nginx was up fine, but the install script of mattermost-omnibus failed out.
Afterwards I setup postgres myself and got it running after some time with the docs. I considered rebuilding the container and using the tar method for installation, but when it started working with some postgres tweaks I’ve tried to just go with it and don’t see anything on the tarball path that would help this.
I expect the SMTP test to function after I enter a good server and credentials. I can’t find a setting for the sender address in the GUI or config.json.
No joy in email notifications. No joy searching for answers to this issue on this forum or search engines. Maybe my search-fu is weak on the topic.
