SiteURL keeps failing on test which is preventing functional plugins.
- Install and start MM
- Open firewall port TCP 8065
- Set DNS record to public IP address
- Set SiteURL to address set by DNS
- Confirm remote user can access MM via public DNS on port 8065
- Run SiteURL Test - Failure
SiteURL Test passes
Debug Log
{"timestamp":"2022-03-07 02:33:04.515 Z","level":"debug","msg":"This is not a valid live URL","caller":"web/context.go:101","path":"/api/v4/site_url/test","request_id":"od5f8t7fuj8mdg7nhe9jp3ggkr","ip_addr":"10.133.1.201","user_id":"1bih9gcz7jy48kknjiooaf9u1o","method":"POST","err_where":"testSiteURL","http_code":400,"err_details":""}
{"timestamp":"2022-03-07 02:33:04.515 Z","level":"debug","msg":"Received HTTP request","caller":"web/handlers.go:156","method":"POST","url":"/api/v4/site_url/test","request_id":"od5f8t7fuj8mdg7nhe9jp3ggkr","status_code":"400"}
NSLookup - Private info omitted
administrator@mattermost:/opt/mattermost$ nslookup selfhost.***
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
Address: 72.208.166.***
administrator@client:/opt/mattermost$ exit
logout
Connection to 10.133.3.102 closed.
administrator@client:~$ nslookup selfhost.***
Server: 127.0.0.53
Dig - Private info omitted
administrator@mattermost:~$ dig selfhost.***
; <<>> DiG 9.16.1-Ubuntu <<>> selfhost.***
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 23900
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;selfhost.***. IN A
;; ANSWER SECTION:
selfhost.***. 3382 IN A 72.208.166.***
;; Query time: 0 msec
;; SERVER: 127.0.0.53#53(127.0.0.53)
;; WHEN: Mon Mar 07 02:48:44 UTC 2022
;; MSG SIZE rcvd: 59
Config.json
"ServiceSettings": {
"SiteURL": "http://selfhost.***:8065",
"WebsocketURL": "",
"LicenseFileLocation": "",
"ListenAddress": ":8065",
"ConnectionSecurity": "",
"TLSCertFile": "",
"TLSKeyFile": "",
"TLSMinVer": "1.2",
"TLSStrictTransport": false,
"TLSOverwriteCiphers": [],
"UseLetsEncrypt": false,
"Forward80To443": false,
"TrustedProxyIPHeader": [],
"ReadTimeout": 300,
"WriteTimeout": 300,
"IdleTimeout": 60,
