When running a slash command and replying to a message, it’d be great if we could also have the ID reference for the parent message being replied to.
Example use case: you have a series of past messages and want to “run a command” using the message as the source of some slash command, and you want it to be ephemeral
Hello, @mlo-tulip
Great idea. May I know if you are open to raise a feature request in the Mattermost Uservoice portal to allow other users to view and cast their votes there? It will also help the development and engineering team to have a better overview on your suggestion and consider implementing it in the future release of Mattermost.
Let me know if you prefer me to raise it for you and I will share the link here. Thanks.
