Is there a doc somewhere describing what DB fields are affected by the “At Rest Encrypt Key” in the config file and on the System Console? I found the en/decrypt routines in the Go code, but I did not find anything that appeared to use them.
Regards,
Brad
Hey @bradhowes,
The At Rest Encrypt Key is undeveloped and not used at the moment. We have a ticket to remove it from the System Console UI for now until the feature development is complete: https://mattermost.atlassian.net/browse/PLT-4230
Ok. Thanks for the reply.
Brad
This issue is not publicly accessible.
