Was unsure on where to post it, but since I found no init-script for CentOS I made my own based on the debian one.
create a file at /etc/init.d/ named mattermost
nano /etc/init.d/mattermost
Copy the script at the bottom inside of it, then make the file executable with:
chmod +x /etc/init.d/mattermost
Add it to the services list:
chkconfig --add mattermost
The script(Make sure you change the paths and user/groups where needed):
#! /bin/sh
### BEGIN INIT INFO
# Provides: mattermost
# Required-Start: $network $syslog
# Required-Stop: $network $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Mattermost Group Chat
# Description: Mattermost: An open-source Slack
### END INIT INFO
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC="Mattermost"
NAME=platform
MATTERMOST_ROOT=/home/admin/mattermost
MATTERMOST_USER=admin
DAEMON="$MATTERMOST_ROOT/bin/platform"
PIDFILE="/var/run/$NAME.pid"
SCRIPTNAME=/etc/init.d/$NAME
CONFIGFILE="$MATTERMOST_ROOT/config/config.json"
cd $MATTERMOST_ROOT/bin
. /etc/rc.d/init.d/functions
# Don't kill named during clean-up
MATTERMOST_SHUTDOWN_TIMEOUT=${MATTERMOST_SHUTDOWN_TIMEOUT:-25}
check_pidfile()
PID="`pidof "$NAME"`"
if [ -n "$PID" ] && [ "`ps -p "$PID" --no-headers -o comm`" != "$NAME" ]; then
rm -f $PIDFILE &> /dev/null
fi
start()
echo -n $"Starting $NAME: "
check_pidfile
if [ -n "`pidof $NAME`" ];
then
echo -n $"$NAME: already running"
success
echo
exit 0;
fi
daemon --pidfile "$PIDFILE" --user "$MATTERMOST_USER" --check $NAME "$DAEMON --config $CONFIGFILE >/dev/null 2>&1 &";
RETVAL=$?
if [ $RETVAL -eq 0 ];
then
echo `pidof $NAME` > $PIDFILE
touch /var/lock/subsys/$NAME && success || failure
echo
else
rm -f $PIDFILE
rm -f /var/lock/subsys/$NAME
exit 7;
fi
stop()
echo -n $"Stopping $NAME: "
[ -n "`pidof "$NAME"`" ] && kill "`pidof "$NAME"`" >/dev/null 2>&1
timeout=0
RETVAL=0
while `pidof "$NAME"` &>/dev/null;
do
if [ $timeout -ge $MATTERMOST_SHUTDOWN_TIMEOUT ];
then
RETVAL=1
break
else
sleep 2 && echo -n "."
timeout=$((timeout+2))
fi
done
# remove pid files
then
rm -f /var/run/$NAME.pid
fi
then
success
else
failure
RETVAL=1
fi
echo
restart ()
stop
start
status ()
check_pidfile
if [ -n "`pidof "$NAME"`" ];
then
echo -n "$NAME is running..."
success
echo
else
echo -n "$NAME is not running..."
failure
echo
fi
exit 0;
RETVAL=0
case "$1" in
start)
start
stop)
stop
restart|force-reload)
restart
status)
status
echo "Usage: $0 {start|stop|status|restart|force-reload}"
RETVAL=1
esac
exit $RETVAL
I am no expert in CentOS, so I am sure the above script can be improved, but at the very least it works as intended.
EDIT: small fix, should now properly use the defined user to run the process.
EDIT2: fixed start/status/stop issues, as well as moved it to use CentOS dameon for better compatibility
