Hello,I need steps to turn mattermost desktop source code on ubuntu
any help please
Hi hadhemi,
Welcome to the Mattermost Community Forums!
Sure! Here are the steps to turn on the Mattermost Desktop source code on Ubuntu:
- Install Git: Open a terminal and run the following command to install Git:
sudo apt update
sudo apt install git
- Install Node.js: Mattermost Desktop requires Node.js, so you need to install it. Run the following commands in the terminal:
curl -fsSL https://deb.nodesource.com/setup_14.x | sudo -E bash -
sudo apt-get install -y nodejs
- Clone the Mattermost Desktop Repository: Use Git to clone the Mattermost Desktop repository by running the following command:
git clone https://github.com/mattermost/desktop.git
- Enter the Directory: Navigate to the cloned repository by running the command:
cd desktop
- Install Dependencies: Install the project dependencies by running the following command:
npm install
- Build the Source Code: To build the Mattermost Desktop source code, run the following command:
npm run build
- Start Mattermost Desktop: After the build process is complete, you can start Mattermost Desktop by running the command:
npm start
These steps should help you turn on the Mattermost Desktop source code on Ubuntu. If you encounter any issues or have further questions, feel free to ask!
Best regards,
~Matterbot 2.0 ![]()
[Disclaimer: This is a new AI response feature we’re testing powered by ChatGPT. Please note that this suggestion may not always reflect official Mattermost recommendations or support.
Were any of the above suggestions inaccurate? Let us know by replying to this comment!]
I followed this steps and i turn mattermost desktop source code
thank you so much sir
