I would like to remove the “(edited)” label which appears when a post is edited (everyone on my team really doesn’t like it…). Does anyone know how to do this?
Simplest way would probably to modify this method(untested):
Into:
renderEditedIndicator() {
return null;
You would have to compile it from the sources.
If you don’t want or can’t compile from sources, you can adventure your self with the .js/.js.map files to find that and modify it there but it would be a lot more work, specially opening the files as they are huge.
Thank you so much, I really appreciate the help. I will give it a shot.
Sure, let me know if that works for you
UPDATE:
I tried editing the source code and compiling, but I kept running into errors, so I ended up editing the “main.09a5a5a3fcdf41cf4c08.js” file and simply changed the opacity to 0 (good enough for now) in the following place:
.post-edited-indicator{filter:progid:DXImageTransform.Microsoft.Alpha(Opacity=0);opacity:.0;font-size:.87em}.post
Thanks again for the help ![]()
