I can access my MM server with any browser and it works great in SSL except safari (Mobile or Desktop). It fails with a generic 50X Server unexpectedly dropped the connection error. I use SSL on my Nginx reverse proxy with a CertCom cert.
If I browse locally (not encapsulated in SSL) or disable the SSL, it works fine. All my other SSL sites work fine. So it’s localized to my Nginx or SSL config for the specific site.
I see 2 errors I think may be a symptom.
[EROR] websocket connect err: web socket: could not find connection header with token ‘upgrade’
[EROR] /api/v1/websocket:connect code=500 rid=[random characters] uid=[random characters] ip=192.168.1.10 Failed to upgrade web socket connection [details: ]
=========================NGINX CONFIG====================
map $http_upgrade $connection_upgrade {
default upgrade;
’’ close;
upstream mattermost {
server 17.0.0.50:8065;
server{
listen 80;
server_name __________.com;
server{
listen 443 ssl;
server_name _____________.com;
access_log /var/log/nginx/chat-access.log;
error_log /var/log/nginx/chat-error.log;
ssl on;
ssl_certificate /etc/nginx/certs/chat/ssl.crt;
ssl_certificate_key /etc/nginx/certs/chat/dssl.key;
ssl_session_timeout 5m;
ssl_prefer_server_ciphers on;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH";
location / {
proxy_pass http://192.168.1.2:8065;
proxy_set_header Connection $connection_upgrade;
client_max_body_size 4G;
keepalive_timeout 10;
