OS: Red Hat Enterprise Linux Server release 7.3
Logs:
[2017/01/18 21:10:09 EST] [INFO] Current version is 3.6.0 (3.6.0/Thu Jan 12 21:00:08 UTC 2017/aafb8be87c79c60df7534b3b69f967c6301b157 e/0cce9c15a3a5411cca6ca90164e94a666bd4b94a) [2017/01/18 21:10:09 EST] [INFO] Enterprise Enabled: true [2017/01/18 21:10:09 EST] [INFO] Current working directory is /opt/mattermost-360/bin [2017/01/18 21:10:09 EST] [INFO] Loaded config file from /opt/mattermost-360/config/config.json [2017/01/18 21:10:09 EST] [INFO] Server is initializing... [2017/01/18 21:10:09 EST] [INFO] Pinging SQL master database [2017/01/18 21:10:09 EST] [WARN] The database schema version of 3.5.0 appears to be out of date [2017/01/18 21:10:09 EST] [WARN] Attempting to upgrade the database schema version to 3.6.0 [2017/01/18 21:10:18 EST] [WARN] The database schema has been upgraded to version 3.6.0 [2017/01/18 21:10:18 EST] [CRIT] Failed to create index Error 1071: Specified key was too long; max key length is 767 bytes [2017/01/18 21:15:12 EST] [INFO] Loaded system translations for 'en' from '/opt/mattermost-360/i18n/en.json' [2017/01/18 21:15:12 EST] [INFO] Current version is 3.6.0 (3.6.0/Thu Jan 12 21:00:08 UTC 2017/aafb8be87c79c60df7534b3b69f967c6301b157 e/0cce9c15a3a5411cca6ca90164e94a666bd4b94a) [2017/01/18 21:15:12 EST] [INFO] Enterprise Enabled: true [2017/01/18 21:15:12 EST] [INFO] Current working directory is /opt/mattermost-360/bin [2017/01/18 21:15:12 EST] [INFO] Loaded config file from /opt/mattermost-360/config/config.json [2017/01/18 21:15:12 EST] [INFO] Server is initializing... [2017/01/18 21:15:12 EST] [INFO] Pinging SQL master database [2017/01/18 21:15:12 EST] [WARN] The database schema version of 3.5.0 appears to be out of date [2017/01/18 21:15:12 EST] [WARN] Attempting to upgrade the database schema version to 3.6.0
MySQL backend, specifically:
Server version: 5.6.28-76.1-56-log Percona XtraDB Cluster (GPL), Release rel76.1, Revision f9b078d, WSREP version 25.14, wsrep_25.14
If I use a local mariadb (mariadb-server-5.5.52-1.el7.x86_64) the upgrade works fine. I’m a mysqlidiot, unfortunately, so any hints here would be greatly appreciated.
Thanks!
