There are no links to create a group and admin console
thank you, problem solved
But there was another problem:
  • the system massege " Вы прикидает команду ." - allowed syntax error.
    I changed the translation file: ru.8f6b5175f9fbb6183510da18b2611478.json
    but changes in the file do not occur on the site mattermost
Are there any ideas?
please edit this setting “combined_system_message.left_team.one”: “{firstUser} прикидает команду.”, on покидает команду in json file
download json file on link “ru.8f6b5175f9fbb6183510da18b2611478.json”:
https://drive.google.com/file/d/18WYEaDEu6MGgMokNyqiIWbQKW1uN8-wf/view?usp=sharing
thanks
PS If you use a mobile phone, there is no problem
Hi @Shevchik, I’m not able to open the file, can you help repost it?
thanks, the problem is resolve and fix in Mattermost v.5.8.0
I have this problem too.
I removed nginx completely from my server, But problem did not solve.
admin_console/ path did not show, blank page appears and in select_team path there is no create team button!
there is no error during run server:
 sudo -u mattermost ./bin/mattermost
{"level":"info","ts":1570435977.011744,"caller":"utils/i18n.go:83","msg":"Loaded system translations for 'en' from '/opt/mattermost/i18n/en.json'"}
{"level":"info","ts":1570435977.012079,"caller":"app/server_app_adapters.go:58","msg":"Server is initializing..."}
{"level":"info","ts":1570435977.0411305,"caller":"sqlstore/supplier.go:223","msg":"Pinging SQL master database"}
{"level":"info","ts":1570435977.11209,"caller":"app/license.go:41","msg":"License key from https://mattermost.com required to unlock enterprise features."}
{"level":"info","ts":1570435977.117458,"caller":"mlog/log.go:165","msg":"Starting up plugins"}
{"level":"info","ts":1570435977.11761,"caller":"app/plugin.go:195","msg":"Syncing plugins from the file store"}
{"level":"info","ts":1570435977.1906106,"caller":"app/plugin.go:230","msg":"Found no files in plugins file store"}
{"level":"info","ts":1570435981.554582,"caller":"mlog/sugar.go:19","msg":"Ensuring Surveybot exists","plugin_id":"com.mattermost.nps"}
{"level":"info","ts":1570435982.5998356,"caller":"app/server.go:216","msg":"Current version is 5.15.0 (5.15.0/Mon Sep 16 19:14:33 UTC 2019/f4f7fd0829d74fcd5e290fd1ba76845af18e553e/ae36beb963c7fe86e95bf33a0ea41b1fe107de9e)"}
{"level":"info","ts":1570435982.6000304,"caller":"app/server.go:217","msg":"Enterprise Enabled: true"}
{"level":"info","ts":1570435982.6000924,"caller":"app/server.go:219","msg":"Current working directory is /opt/mattermost"}
{"level":"info","ts":1570435982.6001256,"caller":"app/server.go:220","msg":"Loaded config","source":"file:///opt/mattermost/config/config.json"}
{"level":"info","ts":1570435982.6390562,"caller":"sqlstore/post_store.go:1301","msg":"Post.Message supports at most 16383 characters (65535 bytes)"}
{"level":"info","ts":1570435982.731733,"caller":"jobs/workers.go:68","msg":"Starting workers"}
{"level":"info","ts":1570435982.7318432,"caller":"app/server.go:423","msg":"Starting Server..."}
{"level":"info","ts":1570435982.7321334,"caller":"app/server.go:489","msg":"Server is listening on [::]:80"}
{"level":"info","ts":1570435982.7335806,"caller":"jobs/schedulers.go:72","msg":"Starting schedulers."}
{"level":"info","ts":1570435982.7576692,"caller":"app/web_hub.go:75","msg":"Starting 8 websocket hubs"}
{"level":"info","ts":1570435982.7727716,"caller":"cors/cors.go:205","msg":"Handler: Actual request","source":"cors"}
{"level":"info","ts":1570435982.7729275,"caller":"cors/cors.go:342","msg":"Actual response added headers: map[Access-Control-Allow-Origin:[*] Vary:[Origin]]","source":"cors"}
{"level":"info","ts":1570435982.7974746,"caller":"cors/cors.go:205","msg":"Handler: Actual request","source":"cors"}
{"level":"info","ts":1570435982.797585,"caller":"cors/cors.go:342","msg":"Actual response added headers: map[Access-Control-Allow-Origin:[*] Vary:[Origin]]","source":"cors"}
{"level":"info","ts":1570435982.8101833,"caller":"cors/cors.go:205","msg":"Handler: Actual request","source":"cors"}
{"level":"info","ts":1570435982.810292,"caller":"cors/cors.go:342","msg":"Actual response added headers: map[Access-Control-Allow-Origin:[*] Vary:[Origin]]","source":"cors"}
{"level":"info","ts":1570435982.8270528,"caller":"cors/cors.go:205","msg":"Handler: Actual request","source":"cors"}
{"level":"info","ts":1570435982.827168,"caller":"cors/cors.go:342","msg":"Actual response added headers: map[Access-Control-Allow-Origin:[*] Vary:[Origin]]","source":"cors"}
{"level":"info","ts":1570435983.9336367,"caller":"cors/cors.go:205","msg":"Handler: Actual request","source":"cors"}
{"level":"info","ts":1570435983.9338741,"caller":"cors/cors.go:342","msg":"Actual response added headers: map[Access-Control-Allow-Origin:[*] Vary:[Origin]]","source":"cors"}
{"level":"info","ts":1570435983.950639,"caller":"cors/cors.go:205","msg":"Handler: Actual request","source":"cors"}
{"level":"info","ts":1570435983.9507284,"caller":"cors/cors.go:342","msg":"Actual response added headers: map[Access-Control-Allow-Origin:[*] Vary:[Origin]]","source":"cors"}
and my config file is:
    "ServiceSettings": {
        "SiteURL": "http://domainname",
        "WebsocketURL": "",
        "LicenseFileLocation": "",
        "ListenAddress": ":80",
        "ConnectionSecurity": "",
        "TLSCertFile": "",
        "TLSKeyFile": "",
        "TLSMinVer": "1.2",
        "TLSStrictTransport": false,
        "TLSOverwriteCiphers": [],
        "UseLetsEncrypt": false,
        "Forward80To443": false,
        "TrustedProxyIPHeader": [
            "X-Forwarded-For",
            "X-Real-IP"
        "ReadTimeout": 300,
        "WriteTimeout": 300,
        "MaximumLoginAttempts": 10,
        "GoogleDeveloperKey": "",
        "EnableCommands": true,
        "EnableOnlyAdminIntegrations": true,
        "EnableLinkPreviews": false,
        "EnableTesting": false,
        "EnableDeveloper": false,
        "AllowCorsFrom": "*",
        "CorsExposedHeaders": "",
        "CorsDebug": true,
        "SessionLengthWebInDays": 30,
        "SessionLengthMobileInDays": 180,
        "SessionLengthSSOInDays": 30,
        "SessionCacheInMinutes": 10,
        "WebsocketSecurePort": 443,
        "WebsocketPort": 80,
        "WebserverMode": "gzip",
        "EnableCustomEmoji": false,
        "EnableEmojiPicker": true,
        "EnableGifPicker": false,
        "GfycatApiKey": "2_KtH_W5",
        "GfycatApiSecret": "3wLVZPiswc3DnaiaFoLkDvB4X0IV6CpMkj4tf2inJRsBY6-FnkT08zGmppWFgeof",
        "RestrictCustomEmojiCreation": "all",
        "RestrictPostDelete": "all",
        "AllowEditPost": "always",
        "PostEditTimeLimit": -1,
        "EnablePostSearch": true,
        "MinimumHashtagLength": 3,
        "EnableUserStatuses": true,
        "CloseUnusedDirectMessages": false,
        "EnableTutorial": true,
        "ExperimentalChannelOrganization": false,
        "ImageProxyType": "",
        "ImageProxyURL": "",
        "ImageProxyOptions": "",
        "DisableLegacyMFA": true,
        "EnableEmailInvitations": false,
        "ExperimentalLdapGroupSync": false,
        "EnableSVGs": false
    "TeamSettings": {
        "SiteName": "Mattermost",
        "MaxUsersPerTeam": 50,
        "EnableTeamCreation": true,
        "EnableUserCreation": true,
        "EnableOpenServer": false,
        "EnableCustomBrand": false,
        "CustomBrandText": "",
        "CustomDescriptionText": "",
        "RestrictTeamInvite": "all",
        "RestrictPublicChannelManagement": "all",
        "RestrictPrivateChannelManagement": "all",
        "RestrictPublicChannelCreation": "all",
        "RestrictPrivateChannelCreation": "all",
        "RestrictPublicChannelDeletion": "all",
        "RestrictPrivateChannelDeletion": "all",
        "RestrictPrivateChannelManageMembers": "all",
        "EnableXToLeaveChannelsFromLHS": false,
        "UserStatusAwayTimeout": 300,
        "MaxChannelsPerTeam": 2000,
        "MaxNotificationsPerChannel": 1000000,
        "EnableConfirmNotificationsToChannel": true,
        "ExperimentalViewArchivedChannels": false,
        "ExperimentalHideTownSquareinLHS": false,
        "ExperimentalTownSquareIsReadOnly": false,
    "ClientRequirements": {
        "AndroidLatestVersion": "",
        "AndroidMinVersion": "",
        "DesktopLatestVersion": "",
        "DesktopMinVersion": "",
        "IosLatestVersion": "",
        "IosMinVersion": ""
    "SqlSettings": {
        "DriverName": "postgres",
        "DataSource": "postgres://mmuser1:mmuser-password111111111@localhost:5432/mattermost1?sslmode=disable\u0026connect_timeout=10",
        "DataSourceReplicas": [],
        "MaxIdleConns": 20,
        "MaxOpenConns": 300,
        "Trace": false,
        "AtRestEncryptKey": "5yg9pc19onio4y959dsiptxd5rxrm6ic",
        "QueryTimeout": 30
    "LogSettings": {
        "EnableConsole": true,
        "ConsoleLevel": "INFO",
        "ConsoleJson": true,
        "EnableFile": true,
        "FileLevel": "INFO",
        "FileJson": true,
        "FileLocation": "",
        "EnableDiagnostics": true
    "NotificationLogSettings": {
        "EnableFile": true,
        "FileJson": true,
        "FileLocation": ""
    "PasswordSettings": {
        "MinimumLength": 10,
        "Lowercase": true,
        "Number": true,
        "Uppercase": true,
        "Symbol": true
    "FileSettings": {
        "EnableMobileUpload": true,
        "EnableMobileDownload": true,
        "MaxFileSize": 52428800,
        "DriverName": "local",
        "Directory": "./data/",
        "EnablePublicLink": false,
        "PublicLinkSalt": "rzwkkcrxxkuh7pzx97now5thj3m4aq7d",
        "AmazonS3AccessKeyId": "",
        "AmazonS3Bucket": "",
        "AmazonS3Region": "",
        "AmazonS3SSL": true,
        "AmazonS3SignV2": false,
        "AmazonS3SSE": false,
        "AmazonS3Trace": false
    "EmailSettings": {
        "SendEmailNotifications": false,
        "FeedbackName": "",
        "FeedbackEmail": "",
        "ReplyToAddress": "",
        "FeedbackOrganization": "",
        "EnableSMTPAuth": false,
        "SMTPUsername": "",
        "SMTPPassword": "",
        "SMTPServer": "dockerhost",
        "SMTPPort": "2500",
        "PushNotificationContents": "generic",
        "EnableEmailBatching": false,
        "EmailBatchingInterval": 30,
        "EnablePreviewModeBanner": true,
        "LoginButtonColor": "#0000",
    "RateLimitSettings": {
        "Enable": false,
        "PerSec": 10,
        "MaxBurst": 100,
        "MemoryStoreSize": 10000,
        "VaryByRemoteAddr": true,
        "VaryByUser": false,
        "VaryByHeader": ""
    "PrivacySettings": {
        "ShowEmailAddress": true,
        "ShowFullName": true
    "SupportSettings": {
        "TermsOfServiceLink": "https://about.mattermost.com/default-terms/",
        "PrivacyPolicyLink": "https://about.mattermost.com/default-privacy-policy/",
        "AboutLink": "https://about.mattermost.com/default-about/",
        "HelpLink": "https://about.mattermost.com/default-help/",
        "ReportAProblemLink": "https://about.mattermost.com/default-report-a-problem/",
        "SupportEmail": "feedback@mattermost.com",
        "CustomTermsOfServiceReAcceptancePeriod": 365
    "AnnouncementSettings": {
        "EnableBanner": false,
        "BannerText": "",
        "BannerColor": "#f2a93b",
        "BannerTextColor": "#333333",
        "AllowBannerDismissal": true
    "ThemeSettings": {
        "EnableThemeSelection": true,
        "DefaultTheme": "default",
        "AllowCustomThemes": true,
        "AllowedThemes": []
    "GitLabSettings": {
        "Enable": false,
        "Secret": "",
        "Id": "",
        "Scope": "",
        "AuthEndpoint": "",
        "TokenEndpoint": "",
        "UserApiEndpoint": ""
    "GoogleSettings": {
        "Enable": false,
        "Secret": "",
        "Id": "",
        "Scope": "profile email",
        "UserApiEndpoint": "https://people.googleapis.com/v1/people/me?personFields=names,emailAddresses,nicknames,metadata"
    "Office365Settings": {
        "Enable": false,
        "Secret": "",
        "Id": "",
        "Scope": "User.Read",
        "UserApiEndpoint": "https://graph.microsoft.com/v1.0/me"
    "LdapSettings": {
        "Enable": false,
        "EnableSync": false,
        "LdapServer": "",
        "LdapPort": 389,
        "BaseDN": "",
        "BindUsername": "",
        "BindPassword": "",
        "UserFilter": "",
        "GroupFilter": "",
        "GroupIdAttribute": "",
        "FirstNameAttribute": "",
        "LastNameAttribute": "",
        "EmailAttribute": "",
        "UsernameAttribute": "",
        "NicknameAttribute": "",
        "IdAttribute": "",
        "PositionAttribute": "",
        "LoginIdAttribute": "",
        "SyncIntervalMinutes": 60,
        "QueryTimeout": 60,
        "MaxPageSize": 0,
        "LoginFieldName": "",
        "Trace": false
    "ComplianceSettings": {
        "Enable": false,
        "EnableDaily": false
    "LocalizationSettings": {
        "DefaultServerLocale": "en",
        "DefaultClientLocale": "en",
        "AvailableLocales": ""
    "SamlSettings": {
        "Enable": false,
        "EnableSyncWithLdap": false,
        "Verify": true,
        "Encrypt": true,
        "SignRequest": false,
        "IdpUrl": "",
        "IdpDescriptorUrl": "",
        "ScopingIDPProviderId": "",
        "ScopingIDPName": "",
        "IdpCertificateFile": "",
        "PublicCertificateFile": "",
        "PrivateKeyFile": "",
        "IdAttribute": "",
        "LocaleAttribute": "",
        "LoginButtonText": "SAML",
    "NativeAppSettings": {
        "AppDownloadLink": "https://about.mattermost.com/downloads/",
        "AndroidAppDownloadLink": "https://about.mattermost.com/mattermost-android-app/",
        "IosAppDownloadLink": "https://about.mattermost.com/mattermost-ios-app/"
    "ClusterSettings": {
        "Enable": false,
        "ClusterName": "",
        "OverrideHostname": "",
        "NetworkInterface": "",
        "BindAddress": "",
        "AdvertiseAddress": "",
        "UseIpAddress": true,
        "UseExperimentalGossip": false,
        "ReadOnlyConfig": true,
        "GossipPort": 8074,
        "StreamingPort": 8075,
        "MaxIdleConns": 100,
        "MaxIdleConnsPerHost": 128,
    "MetricsSettings": {
        "Enable": false,
        "BlockProfileRate": 0,
        "ListenAddress": ":8067"
    "ExperimentalSettings": {
        "EnableClickToReply": false,
        "RestrictSystemAdmin": false
    "AnalyticsSettings": {
        "MaxUsersForStatistics": 2500
    "ElasticsearchSettings": {
        "ConnectionUrl": "http://dockerhost:9200",
        "Username": "elastic",
        "Password": "changeme",
        "EnableIndexing": false,
        "EnableSearching": false,
        "EnableAutocomplete": false,
        "Sniff": true,
        "PostIndexReplicas": 1,
        "PostIndexShards": 1,
        "ChannelIndexReplicas": 1,
        "ChannelIndexShards": 1,
        "UserIndexReplicas": 1,
        "UserIndexShards": 1,
        "IndexPrefix": "",
        "LiveIndexingBatchSize": 1,
        "BulkIndexingTimeWindowSeconds": 3600,
        "RequestTimeoutSeconds": 30,
        "SkipTLSVerification": false,
        "Trace": ""
    "DataRetentionSettings": {
        "EnableFileDeletion": false,
        "MessageRetentionDays": 365,
        "FileRetentionDays": 365,
        "DeletionJobStartTime": "02:00"
    "MessageExportSettings": {
        "EnableExport": false,
        "ExportFormat": "actiance",
        "DailyRunTime": "01:00",
        "ExportFromTimestamp": 0,
        "BatchSize": 10000,
        "GlobalRelaySettings": {
            "CustomerType": "A9",
            "SmtpUsername": "",
            "SmtpPassword": "",
            "EmailAddress": ""
    "JobSettings": {
        "RunJobs": true,
        "RunScheduler": true
    "PluginSettings": {
        "Enable": true,
        "EnableUploads": false,
        "AllowInsecureDownloadUrl": false,
        "EnableHealthCheck": true,
        "Directory": "./plugins",
        "Plugins": {},
        "PluginStates": {
            "com.mattermost.nps": {
                "Enable": true
    "DisplaySettings": {
        "CustomUrlSchemes": [],
        "ExperimentalTimezone": false
    "ImageProxySettings": {
        "Enable": false,
        "ImageProxyType": "local",
        "RemoteImageProxyURL": "",
        "RemoteImageProxyOptions": ""
Hi @ali-zohrevand, these previous threads might have ideas on how you can resolve this:
Thanks for answering, there was no suitable answer in those topic for my problem.
I checked again my log and there was an error:
{"level":"error","ts":1570532727.1871893,"caller":"mlog/log.go:173","msg":"Plugins have been disabled. Please check your logs for details.","path":"/api/v4/plugins/webapp","request_id":"fh4brzd8upduiq8kg6sycqfgth","ip_addr":"172.17.44.7","user_id":"ewsx7wbbktn1p8kytdugkffftr","method":"GET","err_where":"GetActivePluginManifests","http_code":501,"err_details":""}
is this relevant to my problem?
