SOLVED - No system_admin - Can't access system console
Hi
I installed mattermost.
I had a working solution I would say.
After some issues with Nginx, which works more or less now, I wanted to start and play around with mattermost.
But now my only user (called “admin”) can’t access the system console anymore.
I had a single Team and a single user on the entire system.
I tried based on the trouble shooting manual:
sudo ./platform -assign_role -team_name=“FIRST-Team” -email="admin@axample.com" -role=“system_admin”
This doesn’t work
Error: unknown shorthand flag: ‘a’ in -assign_role
What to do?
I removed “admin” from the initial Team and now I can’t do anything anymore with the mattermost installation.
This mattermost is not working for me yet :wink:
I hope I will get there :wink:
Can someone help me here?
And if I try this command from the manual (
I get:
user@cloud$ sudo ./platform roles system_admin admin
user@cloud$ Using config file at /opt/mattermost/config/config.json
user@cloud$ Loaded system translations for ‘en’ from ‘/opt/mattermost/i18n/en.json’
user@cloud$ Server is initializing…
user@cloud$ Pinging SQL master database
user@cloud$ License key from https://mattermost.com required to unlock enterprise features.
I am only running the community version. I am wondering how I can get a system_admin defined :wink:
This problem is solved.
The issue was that I had a Websocket 403 issue.
I had to change the config.json for AllowCorsFrom to “*”.
Quote:
ovizii
I think @bradhowes is absolutely right. I had mm 3.6.2 running and had set
“AllowCorsFrom”: “mydomain.tld”,
and things were working fine.
After an upgrade to mm 4.0.3 I started getting websocket errors which seemed weird so after a couple of hours tinkering with the nginx reverse proxy I simply change above setting to:
“AllowCorsFrom”: “*”,
and everything works again.
So I am not sure if this is a security issue or something like that, but it solves the Websocket 403 issue.
Since the Websocket connection works fine, my user can access the system console again and actually is a system_admin.
So this item is closed.
Chris
