I had successfully set up mattermost 5.40 in Ubuntu 14.04 by following https://docs.mattermost.com/install/install-ubuntu-1404.html#installing-mattermost-server. I could able to access system console if i access application via IP. But when i access the application via domain name, i could not see the system console for the admin user. Also, am getting "websocket_client.jsx:38 WebSocket connection to ‘ws://mattermost.metagis.se/api/v4/websocket’ failed: Error during WebSocket handshake: ‘Connection’ header value must contain ‘Upgrade’ in the console . I had also configured nginx based on this https://docs.mattermost.com/install/install-ubuntu-1404.html#configuring-nginx-as-a-proxy-for-mattermost-server.Please note that
my nginx and mattermost application are in different server. Not sure it is because of this issue.
Hi @Farook,
The error you’re getting means that there are issues with the websocket connections - can you help take a look at our troubleshooting tips here for help:
- https://docs.mattermost.com/install/troubleshooting.html#please-check-connection-mattermost-unreachable-if-issue-persists-ask-administrator-to-check-websocket-port
- https://docs.mattermost.com/install/troubleshooting.html#failed-to-upgrade-websocket-connection
- https://docs.mattermost.com/install/troubleshooting.html#websocket-closed-or-websocket-re-established-connection
