No system console access
I set up a mattermost server (5.10 on CentOS 6). Going to port 8065 everything seemed fine.
Then I went into the System Console and turned on TLS on port 443.
Restarted mattermost server process. I can still get in as a user, but my user can no longer see System Console.
In the database:
Roles: system_admin system_user
      CreateAt: 1556403620744
      UpdateAt: 1556588293632
      DeleteAt: 0
      Username: wwalker
      Password: $2a$10$REDACTED
      AuthService:
         Email: REDACTED
 EmailVerified: 0
      Nickname:
     FirstName:
      LastName:
      Position:
AllowMarketing: 1
         Props: {}
   NotifyProps: {"channel":"true","comments":"never","desktop":"mention","desktop_sound":"true","email":"true","first_name":"false","mention_keys":"wwalker,@wwalker","push":"mention","push_status":"away"}
LastPasswordUpdate: 1556403620744
LastPictureUpdate: 0
FailedAttempts: 0
Locale: en
Timezone: {“automaticTimezone”:"",“manualTimezone”:"",“useAutomaticTimezone”:“true”}
MfaActive: 0
MfaSecret:
I tried creating another user:
sudo ./mattermost user create --email REDACTED --username guru --password REDACTED --system_admin
This user can also log in ; but, cannot see the System Console.
His roles:
Roles: system_user system_admin
Any ideas?
Thank you for your time!
Wayne Walker
Hi @wwalker,
Wondering if this previous thread might help: https://docs.mattermost.com/administration/config-settings.html#configuration.
Also, what is your SiteURL set to (https://docs.mattermost.com/administration/config-settings.html#configuration)?
Hi Amy,
The config looks good, and works (as in the site works, just I get no SystemConsole)
https://mattermost.bybent.com/
I also get this:
Please check connection, Mattermost unreachable. If issue persists, ask administrator to check WebSocket port.
I’m using mattermost without a front end. mattermost is listening on 443, so all connections are direct.
Hi @wwalker,
Wondering if this troubleshooting doc might help: https://docs.mattermost.com/install/troubleshooting.html#please-check-connection-mattermost-unreachable-if-issue-persists-ask-administrator-to-check-websocket-port?
