Upgrading to GitLab Mattermost in GitLab 8.9
I used the following en.json > https://github.com/mattermost/platform/blob/master/i18n/en.json
I put the en.json INSIDE the directory where the mattermost executable is located (in my case: /opt/gitlab/embedded/bin/)
Then I was able to successfully restore my access to the system console.
I may have a particular issue.
I have an instance of gitlab which when I installed, I set up mattermost but didn’t use it at the time.
Now that I’ve upgraded gitlab and plan to use it, I run the interactive upgrade but it says I have 0 teams (expected), but I can’t do the upgrade because I can’t choose any team for the script to keep running. Any help, thoughts?
I having exact same issue as @samypr100
It says I have 0 teams.
gitlab@gitlab:~/mattermost/bin$ sudo -u mattermost -i bash
mattermost@gitlab:~$ cd /opt/gitlab/embedded/service/mattermost
mattermost@gitlab:/opt/gitlab/embedded/service/mattermost$ /opt/gitlab/embedded/bin/mattermost -config='/var/opt/gitlab/mattermost/config.json' -upgrade_db_30
Please see http://www.mattermost.org/upgrade-to-3-0/
**WARNING** This upgrade process will be irreversible.
Have you performed a database backup? (YES/NO): YES
We found 0 teams.
Please pick a primary team from the list above:
I highly recommend that you start a separate thread so that your issue gets more exposure.
Hi @GhostLyrics
I thought this was the thread for upgrade issues with Gitlab. Where should I create the appropriate thread and how should I title it so that it get’s the context of this thread? Thanks!
Hi everyone,
If you haven’t found the answer to your issue by web searching the error message plus “mattermost”, then please use this link to post a new topic in the GitLab Mattermost forum for your troubleshooting issue.
This was recommended in the first message on this thread.
We’ve also been trying to support people who report issues on replies, and realize that it’s really confusing for anyone to follow, so we’re going to close this thread so that people create new topics that can be more easily supported.
