Oh waw, was importing before , now all of a sudden it ouputs that when I try t pip3
Traceback (most recent call last):
File "/usr/bin/pip3", line 9, in <module>
load_entry_point('pip==1.5.6', 'console_scripts', 'pip3')()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 356, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2476, in load_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2190, in load
['__name__'])
File "/usr/lib/python3/dist-packages/pip/__init__.py", line 74, in <module>
from pip.vcs import git, mercurial, subversion, bazaar # noqa
File "/usr/lib/python3/dist-packages/pip/vcs/mercurial.py", line 9, in <module>
from pip.download import path_to_url
File "/usr/lib/python3/dist-packages/pip/download.py", line 25, in <module>
from requests.compat import IncompleteRead
ImportError: cannot import name 'IncompleteRead'
File “script.py”, line 1, in
from mattermostdriver import Driver
ImportError: No module named mattermostdriver
Just by running the script with python3 instead of python
but now I get this new error when running with python3:
File "/usr/local/lib/python3.4/dist-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.4/dist-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/usr/local/lib/python3.4/dist-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.4/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.4/dist-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.4/dist-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.4/dist-packages/urllib3/connection.py", line 284, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.4/dist-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7fadc21c95c0>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.4/dist-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/local/lib/python3.4/dist-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.4/dist-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='10.10.10.6', port=8065): Max retries exceeded with url: /api/v4/users/login (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fadc21c95c0>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "kitchen-schedule.py", line 20, in <module>
foo.login()
File "/usr/local/lib/python3.4/dist-packages/mattermostdriver/driver.py", line 154, in login
'token': self.options['mfa_token']
File "/usr/local/lib/python3.4/dist-packages/mattermostdriver/endpoints/users.py", line 8, in login_user
return self.client.make_request('post', self.endpoint + '/login', options)
File "/usr/local/lib/python3.4/dist-packages/mattermostdriver/client.py", line 137, in make_request
files=files
File "/usr/local/lib/python3.4/dist-packages/requests/api.py", line 112, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.4/dist-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.4/dist-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.4/dist-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.4/dist-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='10.10.10.6', port=8065): Max retries exceeded with url: /api/v4/users/login (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fadc21c95c0>: Failed to establish a new connection: [Errno 111] Connection refused',))
