There are eight separate install docs for Linux:
ee-prod-rhel-6.rst
ee-prod-rhel-7.rst
ee-prod-ubuntu.rst
prod-debian.rst
prod-rhel-6.rst
prod-rhel-7.rst
prod-ubuntu-16.04.rst
prod-ubuntu-1404.rst
They don’t all have the same setup for /etc/nginx/conf.d/mattermost.conf. Is there a best one that can be used consistently? This is what’s there now:
For ee-prod-ubuntu.rst, prod-debian.rst, prod-rhel-6.rst, and prod-rhel-7.rst:
server {
listen 80;
server_name mattermost.example.com;
server {
listen 443 ssl;
ssl on;
ssl_certificate /etc/letsencrypt/live/yourdomainname/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/yourdomainname/privkey.pem;
ssl_session_timeout 5m;
ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
location / {
gzip off;
client_max_body_size 50M;
proxy_pass http://10.10.10.2:8065;
For ee-prod-rhel-6.rst and ee-prod-rhel-7.rst:
server {
listen 80;
server {
listen 443 ssl;
ssl on;
location / {
gzip off;
For prod-ubuntu-16.04.rst and prod-ubuntu-1404.rst:
upstream backend {
server 10.10.10.2:8065;
server {
listen 80;
location /api/v3/users/websocket {
proxy_buffers 256 16k;
proxy_buffer_size 16k;
proxy_read_timeout 600s;
proxy_pass http://backend;
location / {
proxy_cache mattermost_cache;
proxy_cache_revalidate on;
proxy_cache_min_uses 2;
proxy_cache_lock on;
