I am unable to get WebRTC to work.
I used the instructions provided here: https://docs.mattermost.com/deployment/webrtc.html
I am getting the following error:
There was an error connecting your video call
I am getting the follwing console error:
WebSocket connection to 'wss://[IP_ADDRESS]:8189/' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
We are using self signed certificates for the Mattermost server and currently using the certificate provided with Janus in the docker container. (assuming that the crt in the /opt/janus/certs location is correct.
janus.transport.websockets.cfg
; WebSockets stuff: whether they should be enabled, which ports they
; should use, and so on.
[general]
json = compact ; Whether the JSON messages should be indented (default),
; plain (no indentation) or compact (no indentation and no spaces)
ws = yes ; Whether to enable the WebSockets API
ws_port = 8188 ; WebSockets server port
;ws_interface = eth0 ; Whether we should bind this server to a specific interface only
;ws_ip = 192.168.0.1 ; Whether we should bind this server to a specific IP address only
wss = yes ; Whether to enable secure WebSockets
wss_port = 8189; ; WebSockets server secure port, if enabled
;wss_interface = eth0 ; Whether we should bind this server to a specific interface only
;wss_ip = 192.168.0.1 ; Whether we should bind this server to a specific IP address only
;ws_logging = 7 ; libwebsockets debugging level (0 by default)
;ws_acl = 127.,192.168.0. ; Only allow requests coming from this comma separated list of addresses
; If you want to expose the Admin API via WebSockets as well, you need to
; specify a different server instance, as you cannot mix Janus API and
; Admin API messaging. Notice that by default the Admin API support via
; WebSockets is disabled.
[admin]
admin_ws = no ; Whether to enable the Admin API WebSockets API
admin_ws_port = 7188 ; Admin API WebSockets server port, if enabled
;admin_ws_interface = eth0 ; Whether we should bind this server to a specific interface only
;admin_ws_ip = 192.168.0.1 ; Whether we should bind this server to a specific IP address only
admin_wss = yes ; Whether to enable the Admin API secure WebSockets
;admin_wss_port = 7989 ; Admin API WebSockets server secure port, if enabled
;admin_wss_interface = eth0 ; Whether we should bind this server to a specific interface only
;admin_wss_ip = 192.168.0.1 ; Whether we should bind this server to a specific IP address only
;admin_ws_acl = 127.,192.168.0. ; Only allow requests coming from this comma separated list of addresses
; Certificate and key to use for any secure WebSocket server, if needed.
[certificates]
cert_pem = /opt/janus/certs/certificate.crt
cert_key = /opt/janus/certs/privateKey.key
janus.transport.http.cfg
; Web server stuff: whether any should be enabled, which ports they
; should use, whether security should be handled directly or demanded to
; an external application (e.g., web frontend) and what should be the
; base path for the Janus API protocol. You can also specify the
; threading model to use for the HTTP webserver: by default this is
; 'unlimited' (which means a thread per connection, as specified by the
; libmicrohttpd documentation), using a number will make use of a thread
; pool instead. Since long polls are involved, make sure you choose a
; value that doesn't keep new connections waiting.
[general]
base_path = /janus ; Base path to bind to in the web server (plain HTTP only)
threads = unlimited ; unlimited=thread per connection, number=thread pool
http = yes ; Whether to enable the plain HTTP interface
port = 8088 ; Web server HTTP port
;interface = eth0 ; Whether we should bind this server to a specific interface only
;ip = 192.168.0.1 ; Whether we should bind this server to a specific IP address (v4 or v6) only
https = yes ; Whether to enable HTTPS (default=no)
secure_port = 8089 ; Web server HTTPS port, if enabled
;secure_interface = eth0 ; Whether we should bind this server to a specific interface only
;secure_ip = 192.168.0.1 ; Whether we should bind this server to a specific IP address (v4 or v6) only
;acl = 127.,192.168.0. ; Only allow requests coming from this comma separated list of addresses
; Janus can also expose an admin/monitor endpoint, to allow you to check
; which sessions are up, which handles they're managing, their current
; status and so on. This provides a useful aid when debugging potential
; issues in Janus. The configuration is pretty much the same as the one
; already presented above for the webserver stuff, as the API is very
; similar: choose the base bath for the admin/monitor endpoint (/admin
; by default), ports, threading model, etc. Besides, you can specify
; a secret that must be provided in all requests as a crude form of
; authorization mechanism, and partial or full source IPs if you want to
; limit access basing on IP addresses. For security reasons, this
; endpoint is disabled by default, enable it by setting admin_http=yes.
[admin]
admin_base_path = /admin ; Base path to bind to in the admin/monitor web server (plain HTTP only)
admin_threads = unlimited ; unlimited=thread per connection, number=thread pool
admin_http = yes ; Whether to enable the plain HTTP interface
admin_port = 7088 ; Admin/monitor web server HTTP port
;admin_interface = eth0 ; Whether we should bind this server to a specific interface only
;admin_ip = 192.168.0.1 ; Whether we should bind this server to a specific IP address (v4 or v6) only
admin_https = yes ; Whether to enable HTTPS (default=no)
admin_secure_port = 7089 ; Admin/monitor web server HTTPS port, if enabled
;admin_secure_interface = eth0 ; Whether we should bind this server to a specific interface only
;admin_secure_ip = 192.168.0.1 ; Whether we should bind this server to a specific IP address (v4 or v6) only
;admin_acl = 127.,192.168.0. ; Only allow requests coming from this comma separated list of addresses
; Certificate and key to use for HTTPS.
[certificates]
Mattermost WebRTC System Console Config
Gateway WebSocket URL:
Gateway Admin URL:
https://[IP_ADDRESS]:7089/admin
Gateway Admin Secret:
janusoverlord
I know I should change the default password. I will do that once I can prove this thing will work.
https://[IP_ADDERESS]:7089/admin/info is accessible - though giving a certificate error. Once I ‘accept the risk’ I get the response.
