Hi All,
I have a problem with accessing mattermost endpoints with https. After changing the configuration to use FQDN instead of localhost, I get this (for example):
"AuthorizeOAuthUser: Token request failed., Post “https://oshani-tests.cs.huji.ac.il:8443/auth/realms/mattmost/protocol/openid-connect/token”: x509: certificate is valid for localhost, not "
So I would like to know how can I regenerate a certificate for the FQDN (I did not generate any certificate, so I guess one was automaitcally generated when I brought up Mattermost for the first time)
Many thanks,
Oren
