Hi Rochus,
thanks very much for the information,
it’s now [solved] for me also.
When it was still unsolved,
I was using a bitnami VM as the Mattermost server,
(cf Mattermost Team Edition Virtual Machines)
which did not permit (or I couldn’t figure out how)
the settings needed to mmctl_auth_login (yes, it’s a verb) to a local mattermost server without SSL.
To achieve the [Solved] status in my case,
I installed a Mattermost Ubuntu server
(cf Install Mattermost Server on Ubuntu — Mattermost documentation)
and as all is not explained in the above URL,
I had, in addition to “mattermost”,
to apt-install and set
“default-mysql-server” (create a mysql_mattermost_user and and mysql_mattermost_DB)
and “nginx” (create /etc/nginx/sites-available/mattermost.conf and linked it to sites-enabled)
Once this done, like you said, via the web interface,
(in System Console → ENVIRONMENT → Web Server),
I set it to:
Site URL: http://10.0.0.1 #<-- IP of mattermost server on the LAN
Listen Address: :8065
Forward port 80 to 443: false #<-- it was already like that, greyed out, not updatable
Connection Security: None #<-- it was already like that
I also show below the modified parts in the config.json of mattermost
(of course, these are to edit according to your own settings)
"SiteURL": "http://10.0.0.1",
"ListenAddress": ":8065",
"DriverName": "mysql",
"DataSource": "mysql_mattermost_user:mysql_mattermost_userPASS@tcp(localhost:3306)/mattermost?charset=utf8mb4,utf8\u0026readTimeout=30s\u0026writeTimeout=30s",
"MaxFileSize": 10485760000, #<-- for the import, it's about 9GB, by default it's about a 100MB
then after a restart of mattermost service
I could successfully
mmctl --local auth login http://10.0.0.1:8065
from there I could,
with the zip file already on my local server
and so that it could be seen in “mmctl import list available”
mmctl import upload /SomewhereOnMyLocalServer/other_mattermost_server_export.zip
and then the real import in the local server DB
mmctl import process import_created_from_other_mattermost_server_export.zip
and wait until the status is “success” in the output of:
mmctl import job list
As a side note,
I think I understood the why of the mmctl error:
--> unsupported protocol scheme "" <--
it is when you don’t prefix a protocol (http or https) in the
“mmctl auth login” command
as in
mmctl auth login a_host_name
Thanks again,
and cheers
17984403
