after doing command “whereis mattermost” i have this:
mattermost: /opt/mattermost/bin/mattermost /opt/mattermost-back-2018-11-26-19-12/bin/mattermost /opt/mattermost-back-2019-03-13-14-18/bin/mattermost
this is three installed path’s ???
how i can fixed it?
This indicates that you have the original Mattermost (I believe) located in /opt/mattermost/bin/mattermost. I suspect that the rest of the installation paths:
indicates the backups that you have generated on the respective dates:
November 26, 2018
March 13, 2019
If you are not sure which Mattermost is running, please run the following command on your terminal / CLI to verify the directory where the process is running. For example, this is how it looks like on mine - /opt/mattermost/bin/mattermost:
