I’ve been having an issue with Mattermost failing to decode the triggerID I send to create a dialog. Mattermost sends a triggerID, I grab it, and in my JSON I return the same triggerID. I’ve gone through myself to grab them both and be sure I’m returning the proper triggerID, I see no issues anywhere that should be causing it.
Console log:
{"level":"error",
"ts":1604334841.4696991,
"caller":"mlog/log.go:229",
"msg":"Failed to decode base64 for trigger ID for interactive dialog.",
"path":"/api/v4/actions/dialogs/open",
"request_id":"b1cjnzffrjb7ude1igi9ghfnxe",
"ip_addr":"172.18.0.2",
"user_id":"5pru7mxtmjfz8yhby4ndw9q39h",
"method":"POST",
"err_where":"DecodeAndVerifyTriggerId","
http_code":400,
"err_details":"illegal base64 data at input byte 216"}
Looking at byte 216, I found nothing that would result in an error. I have no issue decoding this string on my side in Java, but know that this error originates from the Golang base64 decoder.
Anyone have an issue similar, or know a fix?
Thanks.
(Example triggerID, taken from my latest attempt)
Mattermost sends:
trigger_id=NjV0bjN3NHRhN2dqdHI4NDZiY3VlYmpwcWU6aTF1aWljeXJuN2RianhiM2JwcWdreDFxMXk6MTYwNDMzNDg0MTM1MDpNRVVDSVFDQzFDTTRFVHpXRENEZ243ZDBqSmFUWStzNXZ4cENvbDlWMWx5bVREU3BYd0lnVHpIbE0rdUNqaXhIcTZLb0tTRnhqR1hFZUpwSmJoOHAzRXFLL0FWbFB3UT0
I give it back:
"trigger_id":"NjV0bjN3NHRhN2dqdHI4NDZiY3VlYmpwcWU6aTF1aWljeXJuN2RianhiM2JwcWdreDFxMXk6MTYwNDMzNDg0MTM1MDpNRVVDSVFDQzFDTTRFVHpXRENEZ243ZDBqSmFUWStzNXZ4cENvbDlWMWx5bVREU3BYd0lnVHpIbE0rdUNqaXhIcTZLb0tTRnhqR1hFZUpwSmJoOHAzRXFLL0FWbFB3UT0"
Mattermost’s method of base64 decode (find DecodeAndVerifyTriggerID)
