After upgrading to 5.26 I enabled Bleve and set it to index. After this it seems as though shell commands via mattermost no longer function.
For example, if I execute a simple:
$ /opt/mattermost/bin/mattermost channel list TEAM_NAME
with Bleve enabled, I just get:
{"level":"info","msg":"Server is initializing..."}
2020-08-16T20:30:41.846Z info app/web_hub.go:83 Starting websocket hubs {"number_of_hubs": 2}
2020-08-16T20:30:41.847Z info bleveengine/bleve.go:157 EXPERIMENTAL: Starting Bleve
^C
After I disable Bleve again within the System Console shell commands work again just fine.
I also believe Bleve is not actually indexing when turned on because it stays at 0% indexed on a relatively small Mattermost installation after even two hours of it just sitting there.
That’s really interesting @amy.blais - thanks for pointing that out. Hmm. Well, in addition to this, I’m getting the following with the Bleve hang:
Enabling Bleve search engine makes the Command Line Interface (CLI) mutually exclusive with the running server. This issue does not apply when using mmctl Command Line Tool.
