Using Mattermost 10.1 and Boards plugin 9.0.4, plugin uploaded and installated ok, activate ok too, but once on the boards, it says “Websocket connection closet, connection interrupted”.
I just installated latest plagin from GitHub - mattermost/mattermost-plugin-boards: Mattermost plugin for Boards. This will host plugin only and is independent of Focalboard., by allowing plugin upload, uploaded plugin and enable. All links provided for a solution are dead or redirected.
Anyone have a solution for this? Ive seen that in past versions you should enable EnableReliableWebSockets but it was deprecated.
Any help would be appreciated.
Thanks a lot.
