ChatGPT bot failing to connect, docker instance caught in reboot loop
I’ve deployed this ChatGPT bot docker image for use with our company Mattermost server: GitHub - yGuy/chatgpt-mattermost-bot: A very simple implementation of a service for a mattermost bot that uses ChatGPT in the backend.
The container is caught in a reboot loop as it attempts to authenticate against /api/v4/websocket receiving a 401 response.
That the bot would successfully connect.
websocket connecting to wss://chat.arcadalabs.com/api/v4/websocket
/app/node_modules/@mattermost/client/lib/client4.js:1793
            throw new ClientError(this.getUrl(), {
ClientError: Invalid or expired session, please login again.
    at Client4.<anonymous> (/app/node_modules/@mattermost/client/lib/client4.js:1793:19)
    at Generator.next (<anonymous>)
    at fulfilled (/app/node_modules/@mattermost/client/lib/client4.js:7:58)
    at processTicksAndRejections (node:internal/process/task_queues:96:5) {
  url: 'https://chat.arcadalabs.com/api/v4/users/me',
  server_error_id: 'api.context.session_expired.app_error',
  status_code: 401
Here’s my nginx config, I suspect it’s an nginx problem:
server {
        server_name chat.arcadalabs.com;
       client_max_body_size 50M;
       proxy_buffers 256 16k;
       proxy_buffer_size 16k;
       client_body_timeout 60;
       send_timeout 300;
       lingering_timeout 5;
       proxy_connect_timeout 90;
       proxy_send_timeout 300;
       proxy_read_timeout 90s;
       proxy_pass http://chat;
   location / {
       proxy_read_timeout 600s;
       proxy_cache mattermost_cache;
       proxy_cache_revalidate on;
       proxy_cache_min_uses 2;
       proxy_cache_lock on;
       proxy_http_version 1.1;
listen 443 ssl http2; # managed by Certbot
    ssl_certificate /etc/letsencrypt/live/chat.arcadalabs.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/chat.arcadalabs.com/privkey.pem; # managed by Certbot
#    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
        http2_push_preload on; # Enable HTTP/2 Server Push
        # Enable TLS versions (TLSv1.3 is required upcoming HTTP/3 QUIC).
        # Enable TLSv1.3's 0-RTT. Use $ssl_early_data when reverse proxying to
        # prevent replay attacks.
        # @see: https://nginx.org/en/docs/http/ngx_http_ssl_module.html#ssl_early_data
        ssl_early_data on;
   ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384';
   ssl_prefer_server_ciphers on;
   # HSTS (ngx_http_headers_module is required) (15768000 seconds = six months)
   # OCSP Stapling ---
   ssl_stapling on;
   ssl_stapling_verify on;
   add_header X-Early-Data $tls1_3_early_data;
server {
    if ($host = chat.arcadalabs.com) {
        return 301 https://$host$request_uri;
    } # managed by Certbot
    listen 80;
    return 404; # managed by Certbot
# This block is useful for debugging TLS v1.3. Please feel free to remove this
# and use the `$ssl_early_data` variable exposed by NGINX directly should you
# wish to do so.
map $ssl_early_data $tls1_3_early_data {
  "~." $ssl_early_data;
  default "";
I also posted about this here: Bot is caught in a reboot loop on a mattermost server behind an nginx proxy, failing to auth as bot · Issue #22 · yGuy/chatgpt-mattermost-bot · GitHub
Thanks for any help!
This was a dumb one, I used the mattermost bot token id instead of the actual token secret. Fixed!
