CLI MoveChannel, incorrect member listing
I’ve got two channels that I have removed all members from (in anticipation of moving them), I’ve also re-activated members that were deactivated and removed them as well. However every time I try to process the move I get the error:
MoveChannel: Unable to move a channel unless all its members are already members of the destination team.
How can I troubleshoot this further?
Hello, @agd
I was wondering if you can share the CLI command you ran on your instance to see if we missed out on anything. Will that be okay for you?
Additionally, may I know if you can utilize the following parameter while running the mattermost channel move command on your instance and verify if you are still running into the same issue?
--remove-deactivated-users   Automatically remove any deactivated users from the channel before moving it.
That is the critical thing, Where did you find this documented? I can’t seem to locate it in the current documentation.
Hello, @agd
While this was not included in the official documentation explicitly, you will be able to see it when you run the command below:
ahmaddanial@mattermost:/opt/mattermost/bin$ ./mattermost channel move --help
Moves the provided channels to the specified team.
Validates that all users in the channel belong to the target team. Incoming/Outgoing webhooks are moved along with the channel.
Channels can be specified by [team]:[channel]. ie. myteam:mychannel or by channel ID.
Usage:
  mattermost channel move [team] [channels] --username [user] [flags]
Examples:
  channel move newteam oldteam:mychannel --username myusername
Flags:
  -h, --help                       help for move
      --username string            Required. Username who is moving the channel.
Global Flags:
  -c, --config string        Configuration file to use. (default "config.json")
      --disableconfigwatch   When set config.json will not be loaded from disk when the file is changed.
May I know if the issue is sorted out on your end?
