Cloudflare R2 not support x-amz-checksum-algorithm
but Test Connection is success.
The problem was resolved.
And it worked for a while, but at some point it stopped working.
Is it impossible to upload without using the x-amz-checksum-algorithm
- File Storage - Test Connection : Connection was successful
- Try upload file
Upload file success
"caller": "web/context.go:117",
"err_where": "WriteFile",
"error": "WriteFile: Unable to write the file., unable write the data in the file 20230404/teams/noteam/channels/qdn57b989tf88x9ar846ux6ruo/users/su7n9fzdfifrxkd4uj1txzw7kw/58e7r7ncdfyszcf7h1q8q89wor/image.jpg: Header 'x-amz-checksum-algorithm' with value 'CRC32C' not implemented",
"http_code": 500,
"ip_addr": "10.10.10.10",
"level": "error",
"method": "POST",
"msg": "Unable to write the file.",
"path": "/api/v4/files",
"request_id": "3bwa17txw7rs1jd7sr9cy9q5t5",
"timestamp": "2023-04-04 17:54:05.964 Z",
"user_id": "su7n9fza1cfrxkd4uj1txzw7kw"
