Docker upgrade: got stuck
Fresh docker 7.8.8 install. All good. Upgraded to 8.1. Service unavailable
New install 7.8.8 working well. Changed .env with
MATTERMOST_IMAGE=mattermost-enterprise-edition
MATTERMOST_IMAGE_TAG=8.1
docker compose down
docker compose up -d
now get “SERVICE UNAVAILABLE”
docker logs of running container show continuous repeats of:
{"timestamp":"2023-09-18 10:58:45.299 +02:00","level":"debug","msg":"Worker received a new candidate job.","caller":"resend_invitation_email/worker.go:67","worker":"resend_invitation_email"}
{"timestamp":"2023-09-18 10:59:00.300 +02:00","level":"debug","msg":"Worker received a new candidate job.","caller":"resend_invitation_email/worker.go:67","worker":"resend_invitation_email"}
{"timestamp":"2023-09-18 10:59:02.275 +02:00","level":"debug","msg":"Received HTTP request","caller":"web/handlers.go:163","method":"GET","url":"/api/v4/system/ping","request_id":"izwrqgw4cpgxtezpr8gnap9sue","status_code":"200"}
docker ps shows:
97fa5a337379   mattermost/mattermost-enterprise-edition:8.1   "/entrypoint.sh matt…"   13 minutes ago   Up 13 minutes (healthy)   8065/tcp, 8067/tcp, 8074-8075/tcp, 0.0.0.0:8443->8443/tcp, 0.0.0.0:8443->8443/udp, :::8443->8443/tcp, :::8443->8443/udp   docker-mattermost-1
42f96ab38747   postgres:13-alpine                             "docker-entrypoint.s…"   13 minutes ago   Up 13 minutes             5432/tcp        docker-postgres-1
Got it :slight_smile: I am running the docker behind an hosted Apache2 proxy which routes 80/443 to the 8065 address … needed to expose this ALSO in the docker-compose.yml file.
Not sure I understand how come it did work in the 7.8.8 container though ???
Woo hoo! Thanks for following up, Robert. It’s great to hear that you were able to identify the issue and resolve it by exposing the appropriate ports in the docker-compose.yml file. Regarding your question about why it worked in the 7.8.8 container, it’s possible that the previous version had a different configuration or default settings that allowed it to work without explicitly exposing the ports in the docker-compose.yml file? I have to say though, I’m not entirely sure.
If you have any more questions or need further assistance, feel free to ask!
