I’ve just updated from 4.5 to 4.8 (using the docker stack) and now the upload function crashes the prod-app container.
As the app crashes nothing is thrown into the app log, a few minutes later I can see the container respawning
[2018/03/19 11:20:30 UTC] [INFO] Loaded system translations for 'en' from '/mattermost/i18n/en.json'
[2018/03/19 11:20:30 UTC] [INFO] Server is initializing...
[2018/03/19 11:20:30 UTC] [INFO] Pinging SQL master database
[2018/03/19 11:20:31 UTC] [INFO] Current version is 4.8.0 (4.8.0/Thu Mar 15 23:11:12 UTC 2018/d1ed79a66c7930020b7fda046a11050f5890c84e/6f563c1fa497d123134fd499eb37674eb2511325)
[2018/03/19 11:20:31 UTC] [INFO] Enterprise Enabled: true
[2018/03/19 11:20:31 UTC] [INFO] Current working directory is /mattermost
[2018/03/19 11:20:31 UTC] [INFO] Loaded config file from /mattermost/config/config.json
[2018/03/19 11:20:32 UTC] [INFO] Connection to S3 or minio is good. Bucket exists.
[2018/03/19 11:20:32 UTC] [INFO] License key from https://mattermost.com required to unlock enterprise features.
[2018/03/19 11:20:32 UTC] [INFO] Starting up plugins
[2018/03/19 11:20:32 UTC] [WARN] unable to create user namespace: fork/exec /proc/self/exe: operation not permitted
I had this issue before when I tried to setup my own reverse-proxy. I’ve reverted to the MM provided one which fixed the problem back in the day. Now not even that is saving me
If it’s relevant this is running on AWS Elasticbeanstalk.
Any tips on how I can troubleshoot this? Thank you.
