TheMapSmith
(Stephen Smith)
January 22, 2016, 12:23am
1
I’m very new to AWS and EBS and so I think I probably messed something up.
When I saw 1.4 had been released I downloaded the latest Dockerfile and clicked the Upload and Deploy button in my (only) environment and uploaded 1.4
When it completed deployment I reconnected to the app and it seemed like my team was no longer there.
I thought that rolling back to the previous version would restore it but it doesn’t seem like that’s working.
Can someone explain what I did wrong and if there is any way to fix it?
Thanks,
~Stephen
lfbrock
February 9, 2016, 12:04am
2
Hi @TheMapSmith ,
The current Docker install we have is meant to be a preview - it’s not meant for production instances since it’s using a known password string and contains other non-production configuration settings.
Upgrading will erase the data in the docker container , which is likely the issue you ran into. We’re thinking about updating it to work for production, as several community members have asked for it.
There is also a production docker image built by the community you can try out, but it hasn’t been tested by the Mattermost team.
