Documentation errors
There are syntax errors in the examples on the documentation site
What I found so far …
at mmctl token generate, the example viotates the syntax:
it reads: mmctl generate testuser test-token
it must be: mmctl token generate testuser test-token
at mmctl token list, the example violates the syntax:
it reads: mmctl user tokens testuser
it mus be: mmctl token list testuser
correct documentation
syntax errors in examples
