Troubleshooting Message Formatting Issues in Mattermost - Emmanuel Katto Uganda
Hi Mattermost Community, I am Emmanuel Katto.
I’ve been experiencing some message formatting issues in our Mattermost instance. Specifically, I’ve noticed that:
  • Some Markdown formatting (like code blocks and lists) isn't rendering correctly for certain users.
  • Links inserted in the messages appear but don't behave as expected (e.g., they don’t turn into clickable links).
I’ve checked our settings and made sure everyone is using the latest version, but the issues persist.
Has anyone else encountered similar problems? Are there specific settings or configurations I should look into?
Please let me know.
Best,
Emmanuel Katto
Heya Emmanuel! First off: Welcome to the Mattermost forums! :tada: Second: I’m sorry to hear you’re experiencing these issues. Lemme see if I can help you with some troubleshooting steps:
  1. Double check your Markdown Syntax. Even small errors can prevent proper rendering. Refer to the Mattermost Formating Guide to verify.
  2. Verify that the affected users have proper user permissions and roles.
  3. Clear cache and cookies
  4. Ensure your Mattermost instance and all clients (web, desktop, mobile) are updated to the latest version.
  5. Go to your System Console, review any settings related to markdown and link handling, and ensure support is enabled and configured correctly.
If none of these troubleshooting steps fix the issue for you, I’ll see if I can find your a better answer elsewhere!
