#1 Configuration Settings when running as a Docker container- what should they be?
I have read the manual - Calls self-hosted deployment and Plugins configuration settings
Many settings refer to the port. Which value should be used when running as a Docker container & NGINX serving as a reverse proxy? The exposed port or the internal container port or what is defined in nginx.conf? The documentation assumes standard ports which might not always work in a Docker implementation.
IE - docker compose file
version: "3"
networks:
mattermost:
services:
postgres:
image: gsil-docker1.idm.example.org:5000/postgresql:${POSTGRES_IMAGE_TAG}
restart: ${RESTART_POLICY}
security_opt:
- no-new-privileges:true
pids_limit: 100
read_only: true
tmpfs:
- /tmp
- /var/run/postgresql:uid=1001,gid=1001
volumes:
- ${POSTGRES_DATA_PATH}:/var/lib/postgresql/data
environment:
# timezone inside container
- TZ
- POSTGRES_USER
- POSTGRES_PASSWORD
- POSTGRES_DB
networks:
- mattermost
mattermost:
depends_on:
- postgres
image: gsil-docker1.idm.example.org:5000/${MATTERMOST_IMAGE}:${MATTERMOST_IMAGE_TAG}
hostname: mattermost.example.org
security_opt:
pids_limit: 200
read_only: ${MATTERMOST_CONTAINER_READONLY}
tmpfs:
- /tmp
volumes:
- ${MATTERMOST_CONFIG_PATH}:/mattermost/config:rw
- ${MATTERMOST_DATA_PATH}:/mattermost/data:rw
- ${MATTERMOST_LOGS_PATH}:/mattermost/logs:rw
- ${MATTERMOST_PLUGINS_PATH}:/mattermost/plugins:rw
- ${MATTERMOST_CLIENT_PLUGINS_PATH}:/mattermost/client/plugins:rw
- ${MATTERMOST_BLEVE_INDEXES_PATH}:/mattermost/bleve-indexes:rw
# to avoid Token request failed: certificate signed by unknown authority
# (link: https://github.com/mattermost/mattermost-server/issues/13059 and https://github.com/mattermost/docker/issues/34)
# - ${GITLAB_PKI_CHAIN_PATH}:/etc/ssl/certs/pki_chain.pem:ro
environment:
- TZ
- MM_SQLSETTINGS_DRIVERNAME
- MM_SQLSETTINGS_DATASOURCE
# necessary for bleve
- MM_BLEVESETTINGS_INDEXDIR
# additional settings
- MM_SERVICESETTINGS_SITEURL
- MM_SERVICESETTINGS_LICENSEFILELOCATION
networks:
- mattermost
ports:
- ${APP_PORT}:8065
rtcd:
image: gsil-docker1.idm.example.org:5000/rtcd:v0.11.3
environment:
- RTCD_LOGGER_ENABLEFILE=false
- RTCD_API_SECURITY_ALLOWSELFREGISTRATION=true
ports:
- "8444:8443"
- "8045:8045"
#2 Do I need to add an rtcd entry to nginx.conf?
events {
worker_connections 4096; ## Default: 1024
pid /var/cache/nginx/nginx.pid;
http {
server {
listen 443 ssl;
server_name mattermost.idm.example.org;
ssl_certificate /etc/nginx/gsil-docker1-chain.crt;
ssl_certificate_key /etc/nginx/gsil-docker1.key;
location / {
proxy_pass http://gsil-docker1.idm.example.org:8065;
proxy_set_header Host $host;
proxy_set_header CLIENT_HOST $remote_addr;
proxy_set_header Origin "";
proxy_http_version 1.1;
proxy_set_header X-Forwarded-Host $server_name;
Describe your issue in detail
