? github.com/ethereum/go-ethereum/whisper/shhclient [no test files]
ok github.com/ethereum/go-ethereum/whisper/whisperv6 (cached)
FAIL
util.go:45: exit status 1
exit status 1
Makefile:37: recipe for target ‘test’ failed
make: *** [test] Error 1
Hello, @plainsab
Can you please provide more information on the issue that you are running here?
- The environment that you are deploying Mattermost on (OS version, Go version)
- The documentation / article you referred to for this process
- Screen shot of what you are seeing on your end
That will help to shed more light to this problem. Thanks.
