Export Specific Room Contents
Is it possible to export a specific room with the command line options, or alternatively via a sql query? I’d looked at the bulk export tool but it looks like you can only narrow the export by team.
Hi @storrgie,
The bulk export tool allows you to also export channels: https://docs.mattermost.com/administration/bulk-export.html.
