Hello, I will first explain my case for context.
When a user is logged in the app, he will view a tables with 4 columns and several rows where each row is a channel. I will display an example of the table.
|unread posts | unread mentions | all posts | all mentions|
| 3 | 1 | 99 | 9 | Channel 1
| 7 | 0 | 47 | 5 | Channel 2
The users unread posts and mentions count can be obtained from the API: Mattermost API Reference
Now I want to do the same but for all posts and mentions. Is it possible to do it directly or I have to do a workaround?
Thanks!
