Dear Team ,
Earlier we were using Mattermost community (Teams )version 5.22.2 but for some testing we temporarily upgraded it with Mattermost Enterprise E20 (trail) version . After testing we have removed the Mattermost E20 Trail license but its still showing following message " Edition: Mattermost Enterprise Edition. A license is required to unlock enterprise features."
Any idea how to covert it to Mattermost Community Edition without hampering current setup.
So by default it is working on the Mattermost Team Edition so no need for any action to be taken or is it pending for us to enter any kind of license file to work as Team Edition.
Yeap, it is running on Team Edition if you don’t have any Enterprise E10/E20 license uploaded. So, there is no need for you to upload any sort of Team Edition license.
I have same issue above, when i’m using the trial Enterprise Edition then i like upgrading MM ver.5.31.0 to latest ver.5.38.2 by instruction as following URL: Upgrading Mattermost Server — Mattermost documentation
But after finishing the upgrading, MM ver. didn’t change to ver.5.38.2
do i have to do the other upgrading instruction ?
The fact that the version is still showing the old version could mean that the 5.38.2 server files that you downloaded was not copied over to the installation directory properly.
Can you try out the upgrade cheat sheet that I have here to see if it helps?
With your setup script I think that MM ver.5.38.2 server files was copied to the installation directory. But i can not startup MM service then i got the error log as following.
