I’m trying to customize the translation for specific languages by changing the corresponding JSON files found in the i18n folder. It seems that only some of the front-end string translations can be customized, e.g. the string for town-square channel; while others not, e.g. the string for public channel. I wonder if it’s possible to customize all the front-end string translations? And apart from the translations files in i18n folder, are there other places (db tables, etc.) I need to look into?
Thanks!
