If I edit a channel name, is the incoming webhook still valid?
Hello community,
I have a channel named abc with a relative incoming webhook url https://chat.etc.com/hooks/blabla.
If I change the name of the channel to XyZ, is the webhook url still valid?
Thanks!
Hi luigi and welcome to the Mattermost forums!
If your webhook is bound to a specific channel, then the channel Id is being linked to the webhook upon its creation, so changing the name or URL of the channel should not be a problem, since the channel ID will stay the same and this is the only relevant link here. I didn’t try it out, though, but I’m pretty sure it will not be a problem.
Thanks for the explanation, I will try it out and I will let you know!
It works indeed, thanks:)
Awesome, thanks for confirming :slight_smile:
