I set up a channel to receive notifications using an incoming webhook, and it’s working perfectly except it’s showing my username instead of the one I chose for the webhook.
First, I enabled the following options in System Console > Integration Management:
- Enable integrations to override usernames
- Enable integrations to override profile picture icons
Then, I edited the incoming webhook’s profile picture, display name, and username. The picture and display name updated correctly, but the username did not.
How can I fix this? Thanks!
Mattermost Version: 10.8.1
