Interactive Dialog Dropdowns not working properly on web
Cant scroll through dropdowns in interactive dialogs on web app
Mattermost Version : 5.7
Send an interactive dialog through the api using this json:
{"callback_id":"abcd","title":"Test Dialog","elements":[{"display_name":"Test Dropdown","name":"test","type":"select","optional":false,"options":[{"text":"data1","value":"data1"},{"text":"data2","value":"data2"},{"text":"data3","value":"data3"}]}],"submit_label":"Submit","notify_on_cancel":false}
The dropdown in the dialog should be scrollable
The dropdown only shows the last entry. The rest of the entries can be searched by typing, but do not show up in the scroll view. They are getting hidden behind the title of the dialog.
07%20PM
Hi @anubhav,
A PR to fix this is open here: https://github.com/mattermost/mattermost-webapp/pull/2235.
What’s the endpoint URL do you sent, I even cannot open interactive dialog, it always complains:
{“id”:“api.context.invalid_body_param.app_error”,“message”:“Invalid or missing dialog in request body”,“detailed_error”:“”,“request_id”:“p7furam6m3b43fgcuit5b1ng7a”,“status_code”:400}
