jbaird
January 30, 2019, 5:38am
#1
When making any changes within a specific project on Jira, Mattermost immediately spits out this error:
{“level”:“info”,“ts”:1548826292.1131835,“caller”:“http/server.go:1763”,“msg”:“http: TLS handshake error from xxx.xxx.xxx.xxx:61090: EOF”,“source”:“httpserver”}
curl -v --insecure "https://myurl/plugins/jira/../.../ … --> works and returns fine.
Forward80to443 = True
But unfortunately, I’m receiving no messages to my channel.
Please help.
jbaird
January 30, 2019, 7:36am
#2
The curl results from our Jira server (Windows Server 2008):
C:\Users\Administrator.>C:\curl\curl.exe -v --insecure “https://xxxx.xxxx.com/plugins/jira/webhook?secret=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxeam&team=test&channel=testchannel ” --data '{“event”:“some_jira_event”}'1~
Trying x.xxx.xx.xxx…
TCP_NODELAY set
Connected to xxxx.xxxx.com (xxxx.xx.xxx.xxx) port 443 (#0 )
ALPN, offering h2
ALPN, offering http/1.1
TLSv1.3 (OUT), TLS handshake, Client hello (1):
TLSv1.3 (IN), TLS handshake, Server hello (2):
TLSv1.2 (IN), TLS handshake, Certificate (11):
TLSv1.2 (IN), TLS handshake, Server key exchange (12):
TLSv1.2 (IN), TLS handshake, Server finished (14):
TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
TLSv1.2 (OUT), TLS handshake, Finished (20):
TLSv1.2 (IN), TLS handshake, Finished (20):
SSL connection using TLSv1.2 / ECDHE-ECDSA-AES128-GCM-SHA256
ALPN, server accepted to use h2
Server certificate:
subject: CN=xxxx.xxxx.com
start date: Jan 20 21:14:59 2019 GMT
expire date: Apr 20 21:14:59 2019 GMT
issuer: C=US; O=Let’s Encrypt; CN=Let’s Encrypt Authority X3
SSL certificate verify result: unable to get local issuer certificate (20), c
ontinuing anyway .
Using HTTP2, server supports multi-use
Connection state changed (HTTP/2 confirmed)
Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
Using Stream ID: 1 (easy handle 0x624ff0)
POST /plugins/jira/webhook?secret=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx&team=test&channel=testchannel HTTP/2
Host: xxxx.xxxx.com
User-Agent: curl/7.63.0
Accept: /
Content-Length: 27
Content-Type: application/x-www-form-urlencoded
Connection state changed (MAX_CONCURRENT_STREAMS == 250)!
We are completely uploaded and fine
< HTTP/2 400
< content-type: text/plain; charset=utf-8
< x-content-type-options: nosniff
< content-length: 54
< date: Wed, 30 Jan 2019 06:09:50 GMT
invalid character ‘’’ looking for beginning of value
Connection #0 to host xxxx.xxxx.com left intact
