Hi All.
I have a question for jira integration.(mattermost 5.90 , jira 8.0)
I do on the guide:
Integration did not work.
Hi All.
I do on the guide:
When checking POST request, I got error 400
curl -v --insecure “https://xxx.yyyy.com/plugins/jira/webhook?secret=AmbETIDb1ARpypv9TfFFoLplmsrEBByF&team=zzz&channel=jira&user_id=admin&user_key=admin” --data ‘{“event”:“some_jira_event”}’
subject: CN=xxx.yyy.com
start date: 2019-03-24 23:22:44 GMT
expire date: 2019-06-22 23:22:44 GMT
issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
SSL certificate verify ok.
POST /plugins/jira/webhook?secret=AmbETIDb1ARpypv9TfFFoLplmsrEBByF&team=xxx&channel=jira&user_id=admin&user_key=admin HTTP/1.1
User-Agent: curl/7.38.0
Host: xxx.yyy.com
Accept: /
Content-Length: 27
Content-Type: application/x-www-form-urlencoded
Hi @Ruflex,
Would you be open to sharing your Jira settings in JIRA > Webhooks, as well as your Mattermost Jira plugin settings in the System Console?
Hi @Ruflex,
Your request body could be missing a required key - webhookEvent .
Try to check the board share permission. I had the same issue, but resolved it by giving the correct permission to access the board
Yes, everything is set up as in the instructions. Even more, integration has partially earned. This is manifested in that in the mattermost began to appear posts on the creation of tasks and subtasks:
https://drive.google.com/file/d/1ZLEvpy-lKV5XAH5hDgC8a0eYeroqyh1l/view?usp=drivesdk
But the changes and comments are still not working, for the same reason. The same error in the log:
{“level”:“debug”,“ts”:1553279684.0300117,“caller”:“app/plugin_api.go:650”,“msg”:“Failed to serve HTTP request”,“plugin_id”:“jira”,“Error message”:“WebhookEvent missing”}
Hi @Ruflex, Would you be open to joining our Peer-to-Peer Help channel on our community server for more help on this issue?
I’m not sure what the solution is and I haven’t received feedback from our team in the past few days on this yet.
