Mattermost 7.3.0 uploading stuck on processing
Screenshot 2022-12-01 143024
Issue in one concise sentence
Whenever we try to upload any image or file on mattermost channel, it always stuck on Processing…
open any channel and try t upload the file or image, it always stuck on = Processing… =
It should upload the image or file on channel.
We have setup like this. All VMs are Ubuntu Machines 18.04 version. 1st vm we used for proxy(ngnix) 2nd vm we used for database 3rd vm we have installed main application of mattermost on this server.
i have attached the screenshot.
Also need to add this.
We are using local file storage but when testing it ask for s3 bucket is required.
Hey,
You cannot test the local file storage, which is actually an interesting UI bug in my eyes, you should not be able to click the button if S3 is not enabled, so please ignore this button, you cannot test the local file storage functionality with it.
Can you have a look at your /opt/mattermost/logs/mattermost.log file to see if there are any errors logged there when you try to upload a file in a channel? If so, can you post them here, please?
Also if possible please share the output of the following command:
jq .FileSettings /opt/mattermost/config/config.json
root@MATTERMOST4:/# jq .FileSettings /opt/mattermost/config/config.json
jq: error: Could not open file /opt/mattermost/config/config.json: No such file or directory
root@MATTERMOST4:/#
config.json file is on the same path but it shows this error.
about log i will update after some time.
The error clearly states that the config.json file is not there, so there might be an alternative installation path on your system. Can you run the command with the correct path to your config.json, please?
Agriesser, you are really great, thanks for your help
i am able to trace out the issue. actually i have enable the antivirus but did not installed yet ClamAV.
Can you please help me and give us command how to install clamAV in mattermost application server and activate with mattermost upload scanning.
  1. Update your package lists:
sudo apt-get update
  1. Install ClamAV:
sudo apt-get install clamav clamav-daemon -y
after that how i can link it will mattermost ??
I am able to install and configure the antivirus. thanks for your support. now the upload is working with scanning…
Glad to see you figured it out - I was offline already when you posted your replies. Marking this topic as solved now.
I am having the very same issue, after installation how did you link it to the mattermost?
My error was related to antivirus. actually i have enable the antivirus but did not installed ClamAV.
i have installed the antivirus with belwo commands
sudo apt-get update
  1. Install ClamAV:
after that run this configuration wizard. dpkg-reconfigure clamav-daemon
Ah thanks, I have the opposite issue, I don’t have antivirus enabled (Plugins are disabled), yet I am getting the forever processing message for some specific files (mainly the zip files which include exe files).
Any idea what might be the reason?
PS: I don’t see any error message in the log file either.
ohh ok
then only log can help. you can try to upload files two to three times and share the log during that period. that may help.
