I can not copy and paste my config.json file or make any changes or find my admin user name or password to get into use MM. Please help.
Hi @Cobra16319,
the last time I installed Mattermost it did not create a default admin user at all. Instead the first user to register would gain admin privileges. For this to work you of course need to have registrations enabled, but this in the past was at least the default as well.
Maybe this also solved your questions from MM up & Running Need Default admin Login and Matter Most Admin User K8 Deployment
